Flame straightening 2
GRoberts
Materials
Apr 22, 2002
548
Does ASME address flame straightening anywhere?
As far as I can recall, the answer is no. If you mention which code you are interested in, you may get a more specific answer. It is, of course, done. There is a new standard on repair that is being developed which includes pipe straightening using flame, but that is probably at least a year away from publication.
Our customer mentioned Section VIII, but did not call it out on their purchase order. However, I am interested to find out if it is in any of the sections. I couldn't find it in VIII, but it could be hidden somewhere I didn't look.
GRoberts;
I have not seen any mention of flame straightening in the ASME B&PV code. My reasoning is that it is too difficult to standardize in code words. That is to say, it cannot be used. It would have to be up to the AI to accept this method - which in most cases is accepted provided no metallurgical changes are induced in the material.
bvi - a repair standard by ASME is only a guideline until it is accepted and endorsed by the NBIC. The NBIC is the standard that governs repairs of in-service pressure retaining items.
See U-1(a)(3)
Questions?
Do you have a procedure? Can you back it up?
Does it cover temperatures and ranges? Do you normalize after? Are there metallurgical changes and do they impact the strength?
This is what I would ask. Process and Control.
