Mail-merge type feature in Autocad LT? 1
PAugust
My company supplied a large system that contains over 200 parallel circuits where the only difference between circuits are "in" and "out" connector pin numbers. My customer wants me to create separate wiring diagrams for each separate circuit. I could manually create these 200 separate drawings, but is there a method in Autocad LT to perform a mail-merge type function, where Autocad will automatically plot a separate instance of the diagram for each row of data from a spreadsheet of connector pin number data?
Your question might better be answered in
AutoDesk : AutoCad thread555
