bish0p
Computer
- May 13, 2004
- 1
I need expert advise.
1}Is it safe to use the shield of a 2-wire cable as the grounding wire?
2}Worst case, something drop on the cable and it's damage - cut or bare wire exposed, will it cause electrocution, or explosion if a gas is present in the surrounding area?
thank you.
thank you.
