Asdwinnipeg
I am looking for solutions for the following bridge widening problem. The existing bridge is a five-span continuous precast prestressed girder bridge. The superstructure consists of seven 1473 mm deep precast prestressed concrete I-girders at a spacing of 2.032 m. The girders are post-tensioned longitudinally and act compositely with the 203 mm concrete deck. The existing out-to-out deck width is 14.772 m. There is a existing sidewalk 2.1 m wide with a 1.372 m overhang. The local bridge authority would like to increase the sidewalk width to 3.0 m resulting in a 2.8 m (9.2 ft) overhang. There will be no truck traffic on the sidewalk as it is protected by a jersey type barrier. Has anyone encountered such a large overhang? Can this be built? Do you have any helpful tips or suggest any reference material? Thank you in advance.
