Micro Controller (PIC)
gtvnox
1
does anyone know if there's a microcontroller available out there that is programable using c++?
Every microcomputer is programmable in every language IF:
a.) you have a compiler or interpreter
b.) Sufficient memory ( hi level language needs more)
c.) Suficient speed ( hi level = slower )
d.) can affort the software ( compilers are more expensive than assemblers )
Most popular microcomputers have at least C compilers.
Do you have any particulat CPU in mind ? <nbucska@pcperipherals.com>
