ASME program
dreamschool
29
I am working with pressure vessel manufacturer, any suggestion for certification can help as inspector
You should start out with the following web site;
asme.org
Once there, look for the Codes and Standards folder and continue until you see the accreditation and certification programs. All of the information is there to provide you guidance for ASME B&PV Code certification.
