Captdave
- Jun 14, 2004
- 1
Need some advice on direct burial of stainless steel piping.
An EPC contractor constructing a new power plant has direct buried high pressure natural gas supply lines to the combustion turbines. There is an insulating flange at either end. The line has not been wrapped for corrosion protection and cathodic protection has not been applied. Is this acceptable? Is there a particular code or standard that addresses direct burial of stainless steel piping? I appreciate any advice.
