Actually the Ultimate Load 5000#'s and the actual working load to which the anchor would be subjected, ie 250 #'s falling thru 6' or 8', can't remember which at the moment, are of course different. Never test an existing anchor to 5000 #'s, never post the capacity of the anchor as 5000 #'s. We used to test anchors, subject them to 2500#'s pull incrementally, recording deflection, can't remember permitted deflection, but no set was permitted, or anchor was abandoned, worked in the only jurisdiction that permitted adhesive anchors and multiple eyelets or tie-offs on a single anchor. the roof top drawing would show 4 lifelines tied to one anchor, in my opinion that anchor need to be capable of 20,001#'s at failure, never mind (actually i do mind) the requirement that each lifeline be tied to a separate anchor.
