tsankar
- Aug 1, 2001
- 18
How are error estimates calculated?. For example Pro/Mechanica has an analysis method called "Single Pass Adaptive technique" wherein it runs a first pass analysis with a user defined Polynomial order. Then for the second pass it fixes a polynomial order based on the local stress error estimate.I would like to know how this local stress error estimate is calculated. I don't necessarily require a reply centered on Mechanica. A general idea would suffice.
TS
TS
