Mesh Problem
EbrahimGamaleldin
Geotechnical
Dec 27, 2024
13
Hello Users,
Can such this meshing makes like a convergence issue in the model. I am applying a load on foundation. It is working with small loads, however when increasing the load to higher loads it is not converging the solution.
Thanks,
It depends on what is going on in those regions. You can use the Verify Mesh tool to check the quality of those elements.
