Jan 21, 2025 #1 E EbrahimGamaleldin Geotechnical Dec 27, 2024 13 Hello Users, Can such this meshing makes like a convergence issue in the model. I am applying a load on foundation. It is working with small loads, however when increasing the load to higher loads it is not converging the solution. Thanks,
Jan 22, 2025 #2 FEA way Mechanical Nov 13, 2018 5,131 It depends on what is going on in those regions. You can use the Verify Mesh tool to check the quality of those elements. Upvote 0 Downvote
