test123123
Student
- May 13, 2024
- 6
Is the connection function in FEMAP not valid for thermal analysis?
I wanted to verify the validity of the FEM model by setting RBE2 and all materials to the same CTE and increasing the temperature by only 1 degree to check if the stress remains zero.
However, stress is still being showed in the local place using FEMAP-Connection-glue.
One side of the box is fully constrained with all 123456 degrees of freedom.
