Feb 10, 2025 #1 CAD2015 Computer Jan 21, 2006 2,032 Hi, How could I delete the dependency of a plane? The plan in the picture was created using the surface of the tube. I want to make this plan independent...... How could I do that?.... Thank you,
Feb 10, 2025 1 #2 cowski Mechanical Apr 23, 2000 8,210 One way is to edit the datum plane and turn off the "associative" option in the settings. This will convert the datum plane to a "fixed" datum plane. Upvote 0 Downvote
Feb 10, 2025 1 #4 SDETERS Agricultural May 1, 2008 1,301 You could toss another plane or csys in the same place, edit the sketch, reattach the sketch to the new plane or csys, then move this plane. Upvote 0 Downvote
Feb 17, 2025 Thread starter #5 CAD2015 Computer Jan 21, 2006 2,032 SDETERS, How could reattach the sketch to a new plane or csys? Which is the first step? I want to reattach the sketch in the picture below. The dialog is open, but I do not see something like reattach or similar... Last edited: Feb 17, 2025 Upvote 0 Downvote
Feb 17, 2025 1 #6 MANox Mechanical Apr 2, 2007 130 Hello, You must open sketch and select "reattach sketch" function: Best regards MANok Upvote 0 Downvote
