Plane erase/delete depended..... 3
CAD2015
Computer
Jan 21, 2006
2,031
How could I delete the dependency of a plane?
The plan in the picture was created using the surface of the tube.
I want to make this plan independent......
How could I do that?....
Thank you,
One way is to edit the datum plane and turn off the "associative" option in the settings. This will convert the datum plane to a "fixed" datum plane.
You could toss another plane or csys in the same place, edit the sketch, reattach the sketch to the new plane or csys, then move this plane.
SDETERS,​
How could reattach the sketch to a new plane or csys? Which is the first step?
I want to reattach the sketch in the picture below. The dialog is open, but I do not see something like reattach or similar...
You must open sketch and select "reattach sketch" function:
Best regards
MANok
