Eng_Struct
- Sep 23, 2022
- 65
Hi Group,
I need to specify connection between back-to-back channels to the bottom chord of the joist. The channels are there to support pipe hangers. The total load at each end of the channel will be 1500 lb.
I am envisioning a connection similar to the one below. Instead of full length rod, I will use rods that go through the space between joist bottom chord and will have a washer bearing on top of angle vertical leg.
Will I need to pretension the bolt to get clamp force? Also, any concerns with anti-loosening of the nuts under constant tension load? Any other watch its?
I believe I will have to specify the spacer between the channels but I am not sure how the middle spacer will be welded to the along its full length - I do not want the channels to spread open.
Thanks in advance!
Thanks in advance!
