Connector to casing assembly design 1
AriRnD
5
Hello, I’m having an issue with designing the connection between the connector and the casing. The shape of the connector to be attached is shown in the first image. The mounting position of the connector on the casing can be seen in the second image, and the blue area must remain unobstructed. The cross-sectional view related to the connector installation is shown in the third image, and a hose will also be connected to the left side of the connector (inside the casing). The connector is metal and the casing is plastic part. Do you have any suggestions for the casing design to ensure that the connector can be securely attached to the casing?
Thank you
Screenshot 2025-04-07 102504.png Screenshot 2025-04-07 102616.png Screenshot 2025-04-07 102543.png
AriRnD,​
What you need is called a bulkhead fitting. Your part is not properly retained in your hole. Is the flange connection supposed to be sealed? Forget it.
A bulkhead fitting is retained into the panel by a nut, by screws, or by snapping in. Your hose is attached to a completely separate feature.
AriRnD,​
The design is not finished yet; later the hole will be made to fit the connector. If we use a bulkhead fitting, does that mean the connector needs to be replaced with one that has threads?
That's 30% of the problem. How much room do the other parts that attach to this connector require? How large is this part? How much force is expected to be applied to the connector?
It might be really helpful for you to have a set of well defined design requirements and constraints.
Is the design for the metal connector finished? If not, maybe a groove for a snap ring would work.
Replace your connector with the bulkhead fitting. The bulkhead fitting will attach to your bulkhead and to your hose.
