Help Needed: "Clearance Analysis Object List Contains Invalid Objects" Error in NXOpen
PAVAN67
Automotive
Apr 1, 2025
1
Hello Everyone,
I’ve created a custom program in NX for performing clearance analysis between two components. The program has a UI that allows users to select two components, and it extracts the solid bodies of each component (including those within subassemblies).
Here's how the process is designed:
  1. The first component (checking component) extracts bodies in Layer 1.
  2. The second component (other component) extracts bodies in Layer 2.
  3. The program performs clearance analysis between the bodies in Layer 1 and Layer 2.
However, I'm running into an issue when I try to commit the clearance analysis: I get the following error:
NXOpen.NXException: Clearance analysis object list contains invalid objects
Curious,
what does your program do that the out-of-the-box NX functionality does not do ?
Regards, Tomas
Going out on a limb here and suggest you filter through the body arrays you get from the components to throw out the invalid ones? Like maybe facet bodies and whatnot.
