sdz
- Dec 19, 2001
- 563
AS3600 has rules for calculating the capacity reduction factor (CRF) in Table 2.2.2 which prescribed linear interpolation between Nuot and Muo for axial tension, and between Muo and Nub for axial compression.
I have found for a prestressed beam that Nub can be tension, where I am taking Nu as the externally applied load. This means that applying the AS3600 rules that at Nub the CRF will be greater than 0.6, since Nu is tension at this point.
Is this correct? I think AS3600 needs more clarification on this point.
