nelsonhoover
What is going on when a single phase 240V electric motor running at 1/2 of full load amps, overheats and trips out?
All connections are fine, I'm getting 233 volts directly at the motor. There is no voltage drop across any breakers or contactors. We've tried a new motor with the same results.
Could something such as utility power factor be messing with me? This motor is located a good distance out in the country, away from any sub stations.
Thanks for any ideas on this.
