npsSE
- Aug 19, 2022
- 2
Reference: thread507-436818
I get the same result as OP for 1/4" lag screw capacity. The discrepancy (with NDS) appears to be how Fe is calculated. Since Dr = 0.173 < .25, Fe=16600G^1.84=4637 psi (see footnote 2 of NDS Table 12.3.3), for G=0.50.
It appears that 2018 NDS Table 12J and the online Connection Calculator use the nominal D of 0.25 to calculate Fe=5600 psi.
As other replies point out, instinctively, a 1/4" lag screw should have greater capacity than a 10d common wire nail, so using the higher NDS table value may be appropriate.
