1 Ohm Resistor 6
aware
28
Hi all,
I have some RF receivers that accidentally I broke one of the resistors they contain (see photo).
This seems to be 1 ohm 20% resistor (3 band - Brown Black Gold) and I tried to replace it with 1.2 ohms 5% (although the multimeter shows 2 Ohm...) with no luck.
May I please ask:
1) Is it so critical that it must be exactly 1 ohm AND 20%?
2) Shall I assume that maybe after I broke them, I affected them in a non-reversible way?
3) Any other suggestions?
Alexis Yannopoulos
Mech. Engineer NTUA, MSc
Unfortunately no schematic or model. Only the photo or maybe some extra photos I can take if you suggest so and upload them here...
Rgds
Also after some research, I strongly believe it's a 1uH value.
Alexis Yannopoulos
I ordered some rf chokes and wait for them. As soon as I get them I will try them to see what the result will be and keep you posted.
Thanks for all support
Alexis Yannopoulos
Message to all contributors:
I got some 1uH rf chokes from ebay and YES it worked. I am so grateful to you all. Thanks a zillion.
Alexis Yannopoulos
Thank You very much for the feed back.
Bill
"Why not the best?"
Jimmy Carter
