10% rule for runout inspection fixture
Raddy13
49
I'm working on an inspection fixture for a shaft that has a 0.02 Runout called out on the drawing. I'm not experienced in designing inspection gages and fixtures, so I've been reading up on it and I came across the 10% rule, that inspection gage tolerance should be about 10% of the tolerance it is inspecting. I understand how it applies to things like plug gages, so does that also mean that the spindle which will hold the part should have a Runout tolerance of 0.002?
10% rule mostly applies to the gauge itself so assuming you are using a dial indicator then it needs to have markings showing 0.002 or less. However, the entire measurement system needs to pass a GR&R so the spindle needs to have good runout too. Typically the spindle would be much better than 0.002.
Ah good point, thank you. Is there a guideline for how much runout tolerance I should require for the spindle based on our callout?
Recall that if the part is within less than 10% of the margin you have unfortunate option to accept out of tolerance parts.
What is you process capability? How many good parts do you want to throw away?
Actually, now that I'm thinking about it, shouldn't the spindle runout just be below the measurement error of the dial indicator?
Take a look at Y14.43.
Dimensioning and Tolerancing Principles for Gages and Fixtures.
