medeek
- Mar 16, 2013
- 1,104
If you have a 12:12 pitch roof the two sides of the roof diaphragm are 90 degrees to each other, similar high pitched roofs are close to 90 degrees. How can you consider two diaphragms that are 90 degrees to each other a continuous roof diaphragm? Does this change anyone's analysis of this type of roof?
Usually when I have a high pitched roof I'm dealing with attic trusses and hence an attic floor diaphragm which can partially transfer the shear loads in conjunction with the roof diaphragm. However, there are times where I'm dealing with an actual vaulted (ridge beam) roof and the roof diaphragm is really two planes at an almost 90 degree angle to each other.
A confused student is a good student.
Nathaniel P. Wilkerson, PE
