12volt motor speed controller
andysctt1
I have a 12v automotive starter I am using for a drive motor on a kart but have no way of controlling it yet. it pulls an initial load of 250amps and decreases to aprox 100amps after a couple seconds. i'm using a 70a/h SLA battery. what I need is a controller that doesn't have all the extras on it(braking,reverse.etc). something simple that will decrease amperage so my batteries will last longer and hopefully increase motor life. most controllers I have found so far are listed as 24-48volts very few are listed 12v. similar to golf karts. is it possible that I use a controller to drop amperage to 60-70 amps without damaging the motor? or does the controller control voltage?
The simplest is to use N-channel MOSFET to pulse width modulate the input. ( if the voltage is on 50% of the time
it is equivalent with .50* 12V = 6V )
<nbucska@pcperipherals.com>
You should be able to find a simple square wave generator schematic at Radio Shack. If you have a local electronics store (not Radio Shack) where TV techs buy supplies you could probably get someone there to bread board one for you cheap.
Barry1961
Hi, you wont get very far with this kind of motor, you need something like a golf cart motor.
