MWPC
- Sep 2, 2005
- 104
We are rehabbing a 130 year old courthouse. The roof framing clear spans about 50 feet over a central core using 7' to 9' deep girders built up of 1x12's. The webs are two layers of 1x's (flat) diagonally opposed to each other. The chords are then nail laminated to them and consist of 6 or 8 1x12's with staggered splices and staggered laps at the corners. The ceiling joists frame into the bottom chords. In some areas the rafters frame into the top chords, bracing them. In other areas the roof is higher and the top, compression chord, is not braced. These unbraced top chords have bowed up to 4" in 15' of unbraced length.
I plan to stabilize them by through bolting WT's to each side. My question is should I just stabilize and shim out to the WT's or should I attempt to straighten them by slowly tightening the through bolts? The finishes are being completely removed thus damaging them is not an issue. The duration of the project will be many months allowing some time for the wood to deflect but not 130 years. I have contemplated calculating the WT deflection for 50% of Fb allowable and telling the contractor to tighten the bolts to that deflection and then shim and snug them up. Has anyone had experience with this type of repair?
Thanks for your help.
Ken
Ken
