150 mm Angle Grinder Dust Collection guard- help
rafal222
1
Hi evryone,
i am looking for 150 mm Angle Grinder Dust Collection guard, but i can not find it.
Do you know where can i buy it?
The terminology is dust shroud try searching under that. Below is an example. The 150 mm is hard to find, you may have to use a 177mm
B.E.
 http://www.amazon.com/s/?ie=UTF8&keywords=grinder+dust+shroud&tag=mh0b-20&index=tools&hvadid=3483154757&hvqmt=b&hvbmt=bb&hvdev=c&ref=pd_sl_9uc2mz5bn1_b
What material are you cutting? Grinding? Shaping? Smoothing?
What position is the grinder used in? (Surface horizontal? As if smoothing concrete or moved constantly as if smoothing welded steel surfaces?)
Hand-held grinder moving constantly and held by hand?
