Bfloreshyetech
My name is Brandon Flores; I am doing research on the heat setting process for small extension springs, in aviation applications. The material is 17-7Ph. So far I have not been able to find much online. I am under the Impression that the spring calls out for 400 Degrees (F) for 5 hours, for the heat setting process. A few question I have is; why the exact temperature and time? Is this an Industry standard? If so, where do I find the specs?
Thank you and I appreciate the assistance!
