ScottI2R
- Feb 2, 2005
- 277
Hello all,
We have a 2300V 1500hp Siemens motor Model:CGII frame:5812S that is giving us intermittent outer(rear) bearing temperature high faults. Now our control system monitors this and the trending I found showed temperature variations from a -328 degrees to 1562 degrees F. This was with the motor not running. The wiring is straight from the motor j-box to the input on the plc. I checked that (111.4 ohms) and there are no opens which I believe would cause the 1562 degree value. The negative temperature is what has me looking at the card. What I'm wondering is, what is everybody's experience with RTD failures vs the RTD module in the plc? At present I have a new RTD module in the plc and I am running it monitoring temperature data. Any and all thoughts are welcome and thank you in advance.
Scott
I really am a good egg, I'm just a little scrambled!
Scott
