17Cr for high temperature valve stem
benzy4
15
Hallo everybody!
I know that a lot of valves manufactures use for high pressure sevice the 17Cr material for the valve stem (as alternative to 13Cr / F6).
As 17Cr i know only the 1.4122, but i don't find any ASME/ASTM equivalence.
What ASTM material can I use for this scope????
I need a stem material that I can use for a valve with the range of F91.
Many thanks!
Look at ASTM A 564 for S17400. Table 1 reflects chromium between 15 and 17.5. My assumption is that S17400 is the UNS listing for 17-4 PH material. Others can straighten me out if this is not correct.
See ASME 2277. Also see ASME 2223-3 for A 705 forging and A 693 plate. ASME 2521 applies to A 564 as bolting material. I have not reviewed any of these standards.
OK, Thanks
S17400 is not the right material for high temperature service.
Work Temperatures after 400°C is cause of spinodal decomposition of the martensite phase.
Anybody know the yeld stress og Grade 616 at temperature (400°-600°C)????
Maybe this material can be correct, but I don't find the usual data of the ASME STRESS TABLEs.
Temperatures above 450 degree C eliminate many options. Is the maximum temperature 600 degree C?
Basically, the theoretic material temperature range is the range of A182 F91 ASME VIII, the max allowable temperature for this standard is 1200°F (650°C).
But 600°C is ok for me too.
