ravindranathan
- Sep 30, 2006
- 35
What exactly is meant by "2xLine frequency"in motor vibration readings?
Why is it more prevalent in 2 pole motors?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
They describe all the things I said about it, although I don't believe the amplitudes they cited would be universal (my own experience descrived above for the seven motors with foot-sensitive 2*LF that was not solved by centering is that it was higher than that when measured on the bearings, another paper that I cited measured higher vib than that on the core). They also show the shapes in figure 3 that the stator would be distorted into... ellipitical/oval for 2-pole and 4-lobed for 4-pole. The net force on the stator core is 0, but there are equal/opposite forces that tend to deform the core into those shapes.Siemens said:As can be seen in Fig. 3, for 2-pole motors the electromechanical force will attempt to deflect the stator into an elliptical shape. The primary resistance to movement is the strength of the core back iron and the stiffness of the housing around the stator core, which is restraining the core's movement. On 4 pole motors the distance between the nodes is only 45 mechanical degrees, 1 / 2 that seen on 2 pole motors, thereby making the 4 pole stator core much stiffer to movement resulting in much lower twice line frequency vibration. Calculations on a typical 1000 HP two pole motor at 60 Hz show 120 Hz vibration at the stator core OD of about .12 inches per second, peak, while values for a four pole motor of the same size are only about .02 to .03 inches per second, one sixth to one quarter of this value. This twice line frequency vibration is transmitted through the motor frame to the bearing brackets where it is reduced somewhat in amplitude
Section IV said:A detailed analysis of electromagnetic force waves in an induction motor performed in [11] allowed the author to make the next important conclusion: the main “force wave is produced by the fundamental flux and cannot be eliminated by making the machine free from any imperfections, e.g., eccentricity, stator/rotor dissymmetry, and saturation.” This force wave has the mode number equal to twice the pole pair number and the force frequency equal to the twice the supply frequency [11].
Later, in practical vibration analysis, an idea was introduced that the major source of motor vibration at twice line frequency is a static eccentric air gap [13]–[16]. Modern training courses and diagnostic charts associate vibration at twice line frequency in induction motors with an eccentric air gap in the motor.
However, a number of special researches performed on induction motors tailored for the artificial change of the air-gap eccentricity [17]–[20] are not confirming this statement. Usually, vibration levels at twice line frequency depend very slightly on the amount of air-gap eccentricity [20].
Analysis of vibration signals as a function of the combination of static and dynamic air-gap eccentricity in three-phase induction motors [21] allowed the authors to make a conclusion that the 100-Hz (twice line frequency) vibration component will be unpredictable and vibration monitoring of this component to assess the degree of static eccentricity may not be consistent and clear.
