klaas2
- Aug 24, 2005
- 87
i really have a problem in catia5 r14 to make a assembly of 2 tubes together
1 want to make a setup where i can make a variation in tube lenght
and the tube ends must merge to gather
you must see that as a bike frame
so differant in height and angle's
i cannot get it done
i also cannot use the tubing option since all tubes are not the same
seat tube is differant the head tubes and so on also the are not also round but a certain defined profile
i try simple to connect 2 tubes under a angle let say 72 degrees and try to seamless merge them together but the ends have to be defined before them putting together and that i cannot know the end how that profile looks like
that is why catia has to do for me
am it on the wrong way or cannot be done !
help!!!!!!!!!!
help!!!!!!!!!!
