englisa
- Mar 7, 2012
- 5
I have project that has a below grade heated parking, with surface parking as well as structures above. The main floor which will act as both the main floor for the buildings as well as at grade surface parking is a 2 way structural slab. The overall dimensions of this slab are 120m x60m, and I am wondering if an expansion joint (really a contraction or control joint) would typically be recommended in this case.
I know for slabs exposed to temperature change we would definitely have one, but since this one will be fully within the building envelope I am questioning if this would really be required since it will not see the temperature swing as it will be a controlled environment, although I have been told a general rule of expansion joints at 45m - 90m no matter what in concrete.
Also if so, I guess this joint should be carried through the cast-in-place foundation walls?
Thank you!
Thank you!
