bacon4life
- Feb 4, 2004
- 1,519
How often do NEMA 2-20 amp 120V plugs get used? I routinely see 20 amp recepticles, but I can't recall ever seeing a 20 amp device using one.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
As far as the difference between 15 and 20 amp receptacles, if you compare them from the same brand and series, you will find that the only difference is the "T" slot on the face. The internal contacts are the same. Yes, there are big differences between brands or "no-brands" and even between different series of the same brand.Really though you want 20s in places like work shops and garages so when you plug in air compressors and other power tools that draw 14.9A when running you actually have a chance of them starting.
