2006 BOM TEXT JUSTIFICATION
msupemby
13
When I insert a BOM into a new 2006 dwg, I have noticed that the text we have left justified in the cell is slammed right next to the cell border line ( no "cell padding"). It does not look very good and the BOM can be hard to read. I compared it to my 2005 BOM and 2005 seems to put a space between the cell border and the text. I have searched high & low for an option or setting that I can modifiy to do this. Has anyone else run into this. Your help would be greatly appreciated.
I have noticed the same problem. No solution yet, but I'll let you know if I find one.
Are you using the standard BOM, or Excel-based BOM?
If you are using the standard BOm, try clicking the very top-left of your table. Then in the PropertyManager tree, click on Table Format at the bottom. In there you can choose to center-justify the text.
Not all that helpful if you need to left-justify it, but it could help you some.
Windows 2000
P4 2.40 GHz
Video Card -
Manufacturer: NVIDIA Corporation
Card: Quadro4 900 XGL/PCI/SSE2
Driver: 6.14.10.7184
Pick top of column > Cell Properties > Cell Padding. The problem I have is that after I change the padding and save it as a template, I can't re-use it. If I use the new BOM, the padding reverts to .0012in.
Flores
SW 2006 SP1.0
I have been told by our support that this problem will be fixed in SP1.1. I
I've been looking for a fix to this also.
