I have a simple but fundamental question about the Limit Load Analysis according to 2007 Div.2 part 5, and on the concepts of LFRD approach.
Let's suppose I have to design a vessel with the following data:
Design Pressure: 70psi
Operating Pressure 50psi
According to the assessment procedure (5.2.3.5e) convergence shall be achieved for the prescribed load combinations.
For example, the first global criteria is:
1.5*(P+Ps+D)
Here comes my question: according to the code the first term is the "max allowable working pressure".
Shall I assume the design value (70psi) or the operating one 50psi)?
If use the operating value, then the design pressure becomes "useless", on the other hand it seems weird to me to apply a further magnification factor to the design value, which already includes a safety coefficient.
I found out in 4.1.5.2 two separate definitions, one for Design Pressure, and the other for MAWP, so I'm assuming that the 50psi value shall be used, but I would rather like to have your opinion on the matter.
1.5*(P+Ps+D)
