2011 Drawing BOM not updating
Ellizabeth
Hey guys,
So I have been moving SolidWorks related files (.SLDDRW, sldasm, sldprt, etc..) to PDM and when doing so, I am replacing common components and hardware items on the assemblies. The problem is after when I check the drawing the BOM isn't updating part names and descriptions. It is still showing the information from the original file information, not the updated. Is there something I'm missing or overlooking?
Thanks,
Beth
I am working with SW Enterprise PDM 2011
As for the configurations they are all set to default. I've tried rebuilding, making a new BOM, and even gone as far as to make a new DWG. If you saw the attachment when I right click the item it shows the correct name. I even have SW and the vault set to point to the location where the file is to make sure it pulls only the updated version. I would rather not manually have to edit all the BOM's with this issue as this doesn't really fix the issue.
In the configuration properties you can set how SW gets the Part Number. Are you sure that is set the way you expect it to be? How is it set?
I don't have experience with ePDM. PDM can mess with SW settings.
TOP
CSWP, BSSE
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
Yea, all the default settings are pointing to the Part Number. I don't really want to manually edit all of the incorrect part numbers because this could cause troubles down the road with changes. I'm beginning to think this is a PDM issue as I don't have this issue outside the vault.
Chris,
The reason I am moving it to the vault than replacing the parts is because there are a lot of common components & hardware that is already in the vault that I am using to replace the old parts with. I am essentially copying the assemblies and sub-components from explorer to the vault with the exception of the CC's and hardware and fixing the vault version leaving the original file untouched. the original is than archived.
( I apologize if this is confusing)
I would check out the common parts, update the assy and BOM, then check back in to the vault. There will be no more issues after checking them back out later for all users.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
