KirbyWan
Aerospace
- Apr 18, 2008
- 585
Howdy all,
So we have a PAA line and we had one piece of metal that had a brown color when it came out of the FPL tank. Here's the process:
Solvent wipe
15-30 minutes in Cee-Bee 300LF
5 minute rinse in tap water
10 minutes in Sulfuric acid/sodium dichromate etch
We would normally go on the Phosphoric acid anodize step, but our process operator stopped because it had a streaks. She re-ran it and it got even worse. Check out the pictures below.
The material is 2024-T3 bare per QQ-A-250/4 which had been aged to the -T81 condition before processing.
This was run at the same time as other details made of 2024, though different sheets, which did not have a problem, see the sheet just above in the first picture. I can't figure out why one piece of 2024 would come out so different from parts run at the same time.
Has anyone seen this issue before or recommend a plan for determining the root cause?
Thanks for your help.
-Kirby
Pictures:
Kirby Wilkerson
Remember, first define the problem, then solve it.
Solvent wipe
-Kirby
Pictures:
Kirby Wilkerson
