Krausen
- Jan 1, 2013
- 289
In trying to calculate stud bolt lengths for an odd size 22" Class 600 B16.5 RF flange joint, I've run into an issue. These lengths are not published in B16.5 or by vendors that I've seen. B16.5 points you to use Nonmandatory App. C for stud bolt lengths in unpublished sizes. However, to follow the calc in this appendix one needs to know the minimum flange thickness & stud bolt diameter of the odd size. Since these values are not published either, how would one run this stud length calc?
