Hi all,
I have an outdoor metal-clad switchgear application at 34.5kV, 2500A that required the use of hollow round copper bus. Outdoor condition is hot and high humidity.
A 1/4 x 6'' flat bar rated 2700 A @ 65 deg C rise was the guideline according to this Copper.org website.
If I take the flat bar cross section and applied the equvalent cross section to the round copper bar, is it going to be valid? Say, a 2'' diameter with 0.5'' outer wall thickness?
Also, does heat shrinking the bus derate the temp rating hence the ampacity?
Any feedback will be very much appreciated.
Thanks in advance.
Thanks in advance.
