filippoGDeT
Automotive
- Aug 20, 2015
- 17
Dear All,
hope you can help me to clarify the confusion about the introduction of ISO 8015:1989.
Suppose that in my drawing title block there is not any statement regarding to this norm ( ISO 8015) and , as consequences, the use of independency principle introduced by this standard.
Suppose also that in my drawing title block however is stated : Tolerance not specified according to ISO 2768-mK
Consider now the content of the drawing as per attached picture. It is a simple pin with dimensional tolerance +/-0.05. Which is the tolerance error of the part for straighness of the axis ? 0.2 as per generic tolerance for ISO 2768-2 ?
My drawing still correct/compliant to ISO or it is mandatory to specify in the drawing ISO 8015 when I use Generic Geometrical tolerance as per 2768-2 standard?
Second question:
If not reference are stated to both refrence (ISO 8015 and ISO 2768) should the maximum error of form lie into the dimensional tolerance range?
Thank you in advance to whom can help me to clarify this confusion.
Filippo R.
Second question:
Filippo R.
