Smyers75
Computer
- Apr 22, 2010
- 6
I have an A.O. Smith 2HP, 220Single-Phase pool pump motor that started giving me trouble.
It has been working for the past year or so, but just started having starting problems.
When I turn it on sometimes it starts, most of the time it just hums.
If I give the shaft end a spin, it will always start but I can always hold on to the shaft with two fingers and it will never start.
I did a search here and saw the answers about the cap possibly being bad, but I did the VOM test at 10K and it seems to pass.
After discharging it, it starts out at zero ohms then takes about 10 seconds to swing across the dial.
I read about looking at the centrifugal switch, but I think this one doesn't have one...or is it I just don't know where to look?
I attached a link to the manual for this motor.
Should I try replacing the cap, even though it seems to pass the test?
Shouldn't this motor have way more starting torque than two fingers of a weak, computer programmers hand?
