3/8" A325 Bolt?? 5
satchmo
112
I have a drawing that calls for a 3/8" x 1-1/2" lg hex head bolt w/nut. The associated materials drawing states that "Structural field connections are to be 'Friction Type' and are to be made with high strength bolts (ASTM-A325). ASTM-A325 does not cover smaller than 1/2". Would A354 be an acceptable equivalent if I have spec a 3/8" bolt?
In my opinion, a 3/8" bolt is not a "structural" bolt. Why not use the 1/2" bolt?
Why not ask the person that made the drawing rather than a group of anonymous strangers on the internet?
Maybe the person that specified what was required has passed away?
Yes, ASTM A354 Grade BC are similar to the requirements for ASTM A325 for sizes < 1 inch in diameter.
Thanks for the helpful replies. We wound up installing a 1/2" bolt. Maybe I should have given more detail in the question. This was a 1970's vintage dwg, and the actual bolt was missing from the structural member. It was inaccessible at the time so I couldn't get a measurement of the hole size. I was asking primarily to be prepared to have a 3/8" bolt as equivalent as possible to the A325 spec.
That sounds like a typo. Should it be 3/4"dia.?
A325's are essentially equal to Grade 5's.
When inquiring into the interchangeability of SAE and ASTM bolts I have been told by two different Structural PE's on two separate occasions that the primary difference was in the materials.
Although SAE bolts and ASTM bolt have identical strength equivalents I have been told they have differing modes of failure due the differences in brittleness.
ASTM bolts are ductile compared to SAE equivalents and will yield more when over-stressed before reaching ultimate failure.
I’ve been taught that ideally in a structural connection such as a steel building the connecting members will fail before your bolts, i.e. bolts prying through a the plate in a shear tab.
The combination of the two lends to a more subtle mode of failure versus an explosive failure of a bolt reaching its ultimate strength.
Why can't 3/8" be a structural bolt? It all depends on the scale.
In the Meccano universe, No. 10 is a structural bolt ...
The OPs drawing calls for an A325 bolt and that standard does not go that small; so he can't meet the print requirements. You can't have a 3/8" A325 because it isn't in the standard.
stierman: you forced me to look this stuff up!
We agree that the tensile and yield minimums are the same betwee A325 and SAE gr 5 bolts.
ASTM A325 type 1 bolts are medium carbon, carbon/boron or low carbon steel, quenched and tempered. Elongation in 4D is 14% min and reduction in area is 35% min.
SAE J429 grade 5 is typically paired with ASTM A449. These bolts are also medium carbon steel, quenched and tempered, with 14% min RA and 35% elongation.
The bolts would appear therefore to be identical except for dimensions, the A325 bolt having a shorter threaded length (i.e. better suited to use in shear connections) and a larger head (i.e. a "heavy hex" head).
Is there really a difference in the ductility of these fasteners?
Sorry, where I said "low carbon" I meant "low alloy".
Note that what we're talking about is not substituting SAE gr 5 for A325 construction bolts at sizes 1/2" and larger. We're discussing whether it's necessary or even a good idea for people to substitute 1/2" bolts for 3/8" bolts in a design purely out of a concern over the properties of the bolt material between the two grades. I know the AISC manual doesn't deal with fasteners smaller than 1/2" and that the A325 spec also starts at 1/2", but that shouldn't stop people from using 3/8" bolts in structural applications where they're appropriate.
