3-D magnetostatic simulation software
drniktin
Materials
Feb 21, 2013
1
I'm in urgent need to simulate magnetic flux leakage from corrosion defects in magnetized steel pipes. Could you kindly suggest me the most effective modern 3-D magnetostatic simulation software for this task
Try Amperes 3D:
Integrated Engineering Software
220-1821 Wellington Avenue Winnipeg, Manitoba R3H 0G4
Canada
Ph : (+1) 204-632-5636
Fax: (+1) 204-633-7780
E-mail: info@integratedsoft.com
Web:
When you talk about pipe, you can simulate magnetic flux leakage, however, I think it is difficult to impart a corrosion defect in the simulation software. One thing you can do is that you can vary the wall thickness of the pipe due to corrosion and simulated the same
