Considering the limited space available on an offshore platform the task is to design a 3-phase separator that can accomodate possible slug of well fluid. Options available are: (unless someone has better idea)
(i) Have a slug catcher followed by a separator, but this option requires a great deal of space.
(ii) Built the slug catching capacity within the horizontal 3 phase separator, which may result in oversized separator and have weight problem, lifting and rolling on the platform as well as localized weight on the structure
(iii) Install a Control valve upstream of separator and control the separator liquid levels and pressure by controlling the upstream control valve. This option is more apealing as I can have a controlled flow to the separator and any slug can be mitigated with in the 24"x30 KM pipeline upstream of control valve.
Your expert opinion will be valuable.
