ktgottfr
- Apr 14, 2008
- 46
Greetings all - I have recently started a project for a prototype engine. There are some papers in the literature that suggest 304 stainless hardened to 1/4-1/2 hard (125ksi UTS 80ksi yield) will have the fatigue properties we want for UHCF. However, I am having a hard time sourcing this material.
Does anyone know where I might be able to source 1/2" thick 304 plate/sheet that has been work hardened? Every potential source I have contacted so far has turned out to only stock the annealed plate even if they advertised work hardened plate.
Am I on a wild goose chase here? Is 1/4 hard 304 plate even something that anyone has ever offered? Will I need to order it straight from the mill to get this material? Does anyone know if a common rolling machine can do this sort of 25% thickness reduction on a 5/8" thick plate to get it down to 1/2" thick - or is this beyond the capability of a typical rolling machine a shop might have. Any suggestions or advice would be appreciated! Thanks everyone!
-Kristjan
-Kristjan
