Erin Foster
Specifier/Regulator
I am not an engineer but desperately looking for an answer to this question and hope someone on this forum might know:
I provided 316 stainless steel handles for outdoor kitchen cabinets that are under a covered patio.
The screws that came with the handles were not long enough to extend through the thickness of the drawer and drawer front.
I purchased screws that fit, but they are 304 stainless steel. I can’t find them in 316.
The 304 screws are only visible when you open a drawer, so some tarnishing will be fine as long as it doesn’t affect the 316 handle or surrounding resin cabinetry. Does anyone know if using a 304 screw will increase the likelyhood of rust or tarnish on the 316 handle? Or if it would “bleed” tarnish onto the surrounding surface? Are the two types of stainless steel ok to touch?
Thank you!
Erin
Thank you!
Erin
