3D Plastic Beam
ankushaggarwal2
Aerospace
May 22, 2007
26
I want to model a 3D elasto-plastic beam and calculate the axial strains. The Beam4 is described as Elastic beam and Beam24 although named as Plastic, is for thin walled beam.
Please help me, which beam I should use. Because, with elasto-plastic properties and Beam4 element, the problem gets solved (but I am not sure, if it uses the defined data table) and I can only get the elastic strain from it (as defined in the element library).
Thanks!
Thank you very much!
Just one more thing.
I want to get the axial strains in the beam. It is written as EPELDIR in the output definitions. But, how can I get it, I am not being able to figure out. By using *get or ETABLE or by some GUI, please help me in this.
You could just "Query Results" if you're only interested in one or two values. If you wish to write a macro of some sort you will need to use element tables or *get,,etab. I think ETABLE is probably the easier route to go here. Have you ever used element tables? The documentation does a good job explaining them. Read that and I'm sure if you have any specific questions the helpful folks here will be more than happy to assist.
In "Query Results", there is no option for axial strain. However, I am able to use ETABLE. Thanks for the suggestion. Actually, I have to use it as
ETABLE,name_of_table,EPEL,DIR
Before, I was thinking that EPELDIR is one (as given in the manual) and was not able to use it.
