Hi All,
As sort it, I have a 3D 3500 CPX HD Printer from 3D Systems, recently I face some problems in the parts quality, after the build is done and removing out the platform I notice that there are some dust effect on the platform (before removing the parts), around the parts and mostly in the X direction and very rare in the Y direction and some times on the surface of the built parts.
I try several times to solve this problem by increase or decrease the temp but the result was the same even when I change the quality method on the software (UHD - or XHD) which to be the highest quality to build parts, and it's effecting the cleaning process for the parts as well as effecting the casting into silver or gold materials, since I'm working in the jewellery field.
For your information, I'm using Visijet S-400 as a support materials and Visijet Hi-Cast and parts materials, however I requested our area re-seller to solve the but alot of trials without any positive solution !!!!
So, anybody experience this type of effect on the parts, I will be thankful to share his knowledge and solutions with me.
Thank you all, and have a good day.
BR,
BR,
