Hello!
First time posting here, hopefully someone here can help!
I am interested in seeing if there is a function (or implementable macro) that lists all the parameters that are related to a geoset. This would allow me to easily check geosets to make sure the correct parameters are utilized, without having to individually check each element/geometry using historical graph or selecting each element.
My ultimate goal would be to create a macro that would replace a certain parameter for all elements in a geooset that I select. The macro would:
1. Select a geoset containing elements/geometry that are parameterized
2. Select parameter that I want to replace
3. Insert new selected parameter in the same equation
4. Repeat for all geometry in a given geoset
Any input would be much appreciated. I have little VBA experience, but I am learning it on my own time.
Thanks!
Thanks!
