sunrays
- Sep 28, 2005
- 27
I need to send the speed reference from Drive A to Drive B over a distance of 800 Meters. Application is not very critical from the speed accuracy point of view. A +/- 10 RPM is good enough.
Option A: Use a field bus option but length is an issue. I am given to understand that I need to use Fiber Optic Cables to over come the distance, which add to the cost.
Option B: 4-20mA signal. I need a converter at both ends to convert the 0-10V Signal of Drive A to 4-20mA and 4-20mA back to 0- 10 V at Drive B since the drives can deliver/accept only Volts. The cable proposed to be used will be shielded one.
What is the maximum distance permissible with a 4-20mA option? Would I face any loss of signal over this distance?
Thanks!
Thanks!
